travelers
Eastern Pa
Love the stance on your Bullitt, Cam.
Got my new wheels and tires on. Now I'm thinking I need Brembos on the front.
They look really good, but then I also have them on my car.
weather man
Persistence Is A Bitch
MN
Kuplex
Software Developer
Knoxville, TN
Installed my new OEM headlamps. Looks so much better. I did it during my lunch break. Half the office was asking wtf I was doing with my bumper off in the parking lot lol
Bill220
travelers
Eastern Pa
Well with the temp hitting 67* today, I pulled the car out of storage and cleaned it and took it for a ride to heat cycle the rear gears. Also shifting to help get the clutch seated. I missed driving it.
TenSpeed
Boss 227..every damn time
Michigan
Just peeled most of the Plasti Dip off the rear of the car. Still deciding what I want to so that when the warm weather is here to stay, the car looks good. 66° right now in Michigan!
bunits19714
monroe , mi
washed 2 months of general storage dust and 180+ miles of moist road grime off of it today and drove it about 40 miles- This summer is going to be fun with the 770+ rwhp ponies- Now I just have to go get my own drum of e-98 to make my own e-85 because the tank the car left the tuners with is going fast.
bujeezus
Alabama
Changed out coil boots and brake reservoir tank. Coil boots went off without a hitch. Totally fucked up with the brake reservoir...see pissed thread.
AnotherS197GT
Serial Valve Dropper
USA
Removed my blowfish bracket, MGW shifter, and reinstalled the stock shifter in anticipation of my upcoming trans swap.
jsimmonstx
Comal County, TX
Throttle linkage fabrication. I needed more feedback when I push the gas pedal, so I make a bracket for a secondary (stronger) return spring.
Changed my oil and discovered 4 bolts from the front of th oil pan were missing. Looked on the bench and there was a little baggy with 4 bolts marked oil pan. Lol. Didn't leak though. I guess that means everything is lined up ok and the rtv is good.
Put in my rear sensors in with my mini cat sims. We'll see how well they work. Gotta get by smog in the next couple of weeks.
nyuk98GT
Infrequent poster
Chesterfield, MO
Installed an MRT after-cat H-pipe. Deeper tone at idle with a little more volume. Heavy throttle test alongside a service road soundwall confirms deeper tone and definitely increased volume. Very nice! :headbang:
Took a hard look at the stock OTA pipes and it sure looks like a lot of non-mandrel bent tubing in those pipes, lol. OTA pipes are on the list now. :pepper:
Chris
ghunt81
New parts on old junk!
Clarksburg, WV
I don't have my rotors yet but got to working on my S550 brake swap yesterday...this may not work as well as I'd hoped. I bolted the caliper on (with the original rotor still in place) and put the wheel on...not even close to clearing. Unless the 14" rotors have a thicker hub section I'm either looking at spacers, or selling these and just buying brembos (honestly it's been nagging at me since I bought these things that I should have just bought some reman brembos instead)
Bill220
61 and sunny today, no crap on the roads, the car is running great so I'm taking her out for the afternoon. Just gave her a quick ONR wash.
I still have to re-polish the areas I Dr. Color Chipped (leaves wicked swirls) and get my Aeroforce gauge in but I'm taking advantage of the day.
I still have to get the gas smell out of my interior from the fuel pump swap. It's not bad but it's there. I left the back seat out and black rubber pump cover off to make sure the tank gasket isn't going to leak. I have to fill her up today.
