Spring compressor for removing lowering springs needed?
Rapture
Do you think I'll need one to take out my SR lowering springs and put them back in?
ghunt81
New parts on old junk!
Clarksburg, WV
TECHNICALLY...you're supposed to use one.
Realistically, you don't have to. You can do it by supporting the lower control arm with a jack, removing the center strut nut and the four strut plate nuts, and lowering the jack to release tension on the spring and take everything apart as it comes out.
Then, when you put it back together, push down on the spring and strut assembly by the strut mount to start the center strut nut and tighten it as much as you can, then put the strut back in the car and put everything back together, put a jack under the control arm to get it to ride height and do the final torquing to the strut nut.
The first time I did springs I used a spring compressor, and honestly the method above is way easier.
No, Just jack the car up. Loosen a shock bolt and pull it when tension is relieved from the shock. Keep jacking and the spring will pull right out.
It's super easy.
Rapture
It's super easy.
Jack from lower control arm? Sorry I've never actually worked under the front of my car. Only the rear. Rear suspension is easy.
Rapture
Oh I see. So you push the control arm up almost as if you were using a spring compressor? How do I know when it's compressed enough to remove those nuts?
JeremyH
3V Fuel Guru
Virginia Beach
No, never used one.
It doesn't need compressed per say to remove the hardware, just use the jack pressed up enough to support the control arm so it doesn't get pushed down when you remove the bolts.
RocketcarX
95% of my weight is fuel
Colorado
If you aren't too sure, you could always pull the strut/spring out as an assembly and have a local shop swap the springs.
Realistically you should be doing the struts and strut mounts, along with spring isolators, which means you could assemble all of that and swap out the factory junk for your new assembly. Or are you literally just doing struts?
ghunt81
Clarksburg, WV
You just have to have the car sitting on the jack "at ride height" i.e. with the spring compressed as if the car was sitting on its wheels. This effectively compresses the spring so something won't go flying apart when you take that top strut nut off. Keep a jackstand under the k-member, then when you let the jack down it will rest on the k-member and the control arm will come down until the tension is off the spring.
Rapture
Makes sense. So the wheel is still off the ground but the car is at ride height because the jack is under the control arm, right? Then lower the car down onto the K member and the strut spring assembly will just hang. Is this right? Kind of like the rear with jacking the differential and the putting jack stand on either side and lowering the car onto stands and letting the axle hang. Is this right?
Rapture
I see a spring compressor being sold on Walmart market place for 18 bucks. Looks pretty solid. I might order this up. Wouldn't hurt to have since I'll be eventually doing coil overs.
01yellerCobra
San Diego, CA
You might want to sit back and think about that one a little more. Springs aren't something to mess around with. At $18 I can't imagine it being very good. I doubt Harbor Freight is even that cheap.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Rapture
Should I grab the harbor freight instead
Rapture
Should I grab the harbor freight instead? These really aren't too high tech of tools I really can't see how anyone could mess one up.
You rent one and then you have to wonder what jackass had the spring compressor before you and what he did with it.
01yellerCobra
San Diego, CA
I have a harbor freight compressor I picked up a few years ago. A buddy of mine picked up the big one a few months ago. I want to say it was less than $100. But worked pretty good.
Tbone
London, On Canada
Up here in canada i can go to canadian tire and "rent" a spring compressor. You pay full price just in case you dont return it, but bring it back and they give a full refund. Can do almost all specialty tools this way. Nothing in the US like that at an autozone or something?
Bingo
Because street car
Phila, PA
Depending on how much "low" the springs have, they won't be under much pressure at ride height and would be a super easy job using the jack method.
