RED09GT
Equal Opportunity Offender
Okay, my car now has a 6 point rollbar and I need to put in a 5 point harness.
The shoulder straps are pretty obvious and the crotch strap will be mounted with one of the brackets that bolts to the seat mounts.
What are you using for the lap belt? I have seen several examples using the stock seat belt bolt on the outside, what do I do about the inside lap belt? I want to make sure that it will not only pass tech, but also protect me if something goes wrong.
Can I just drill a hole opposite of the outside seat belt mount and use either 3" plates, or 3" fender washers on both sides of the bolt? Will this be strong enough?
Anyone have pictures of what they have done?
