Barton vs mgw short throw
gtkid
Morning all. I've just purchased a barton short throw shifter with the sr gasket. Told a fellow mustang enthusiast and he told me to return it and spend the extra 100 on the mgw. Thoughts? Is it less noisey? Tia 2012 gt 6m
if you search...... you'll find MGW > Barton......... /thread
redfirepearlgt
Spend the extra C note. If you can't drive a manual shift Mustang with an MGW shifter you need to turn in your license. It's that nice of a shifter. The only thing I miss about my 13 stick shift car is the MGW shifter.
gtkid
Shit alright thanks a lot you guys. Will be returning the barton. Great advice thanks again! Should I keep the gasket though?
Boaisy
Dark Knight
Memphis, TN
This. Barton is good, but I even had the 2 post version on my '12 Brembo, and it still had areas that needed improvement. They have a newer Hybrid 3 system now (never tried it), but it is the same price range as the MGW. If you are strapped for cash, then Barton 2-post. Otherwise go ahead and dump the money on a MGW.
oldVOR
Northern Virginia
You will not need the gasket with a MGW shifter since it replaces the entire shift box itself. You will need to get the car in the air since the MGW does have some aspects of the install that require access from below. Jack stands and working on your back is easy enough. MGW's video install is spot on.
Mustang dog
I bought both and returned the Barton. They both looked really good. What sold me on the MGW was the sheer weight of the unit. almost a full pound heavier. Than the Barton, my thought was that it would deaden or help at least vibration through the shift handle.
Most likely not needed but that was my goofy reason...
gtkid
Damn the mgw is damn near 2 c notes more. May just keep the barton as I'm paying off a dui atm
Wes06
....................................fucking dumbass
Macman45
Resident Geriatric
Atlanta / Bay Area
I am confused looked on both websites
MGW $470
Barton $475
Barton used to make a cheesy 2 post for around $300. Probably what the OP has. In addition to the DUI apparently. Guess they discontinued it in favor of the hybrid 3 post.
And if you wanna get real technical isn't the RaceSpec $475 or the same as the Barton now?
Either way there isn't a price difference between the two.
Boaisy
Dark Knight
Memphis, TN
AM still sells the single and 2 post versions. It seems like the Hybrid 3 is their attempt to be an MGW.
AnotherS197GT
Serial Valve Dropper
Tampa, FL
Yet it still mounts to the chassis... I don't understand why they do that. Probably so it doesn't look like a complete rip off of the MGW.
Another MGW vote here. Don't waste your money on other shifters because you'll end up with an MGW eventually.
gtkid
Agreed, I deserved it. Expensive lesson learned, 8k to be exact.
Well super appreciative of all the thoughtful responses of knowledge. I guess I'll just live with the stock shifter until my dui is played off and put in the mgw. Thanks again everyone.
redfirepearlgt
Wise decision on the MGW. As for the DUI, someone cut you a break whether you realize it or not. You could have killed someone's father/mother/son/daughter/friend. I hope you learn from the mistake rather than blindly and arrogantly repeat it in the future. I wish they would clamp down on texting and driving laws and enforce equally as strict punishment for killing someone while texting and driving.
