Rpm427sc
Wheels are APEX 19x11 ET52 Anthracite EC-7's. I bought the Ford Racing Hub kit w. ARP studs pre-installed, they are around 3in. It took me a long time to find those wheel spacers, I was almost ready to settle for the Eibach pro spacers and knocking the hardware out that comes with them. The spacers in that pic I found from a vendor on Amazon, and cost me about $30. I checked all the dimensions on them and they were perfect and fit great. The trick I used on getting the 15mm spacer to work (vice a 20-25mm), was setting the factory camber adjustment bolts to max positive setting (which moves the hub away from the strut body, and using camber plates to bring the whole strut/hub assembly back into 1.5-2deg neg camber. Sadly I don't have a shot of the car on the ground right now, its basically in "final assembly", hoping to have it done in the spring.
As it sits now:
As it sits now:
