GT500 Mount Reversal
Bad Horsie
Ocean NJ
Getting ready to install Steeda sports( 1"drop),Koni STR's,and Gt500 mounts on the front this weekend. Already did the rear.1.25 with PHB last weekend. noticeable improvement on test drive
My question is it a big deal if i don't reverse the mounts(arrow towards the engine) right now? Hpde Track event coming up in a few weeks and I thought the little more neg camber would help me out here. could always flip it when I get back home and reset the toe....unless it's not worth the trouble..
I read some threads on this but the mount reversal was more specific to 1.5 and greater drops.
Thanks
RocketcarX
95% of my weight is fuel
Colorado
Back when I was on your typical 1.5 inch drop springs I ruined a set of tires inside of one oil change interval because of the excessive camber before i learned about reversing the mounts.
Gabe
Whippled Coyote
I've had mine arrows-out for about 5 years and my only real tire wear issue is on the rear, lol.
Seriously, I only get minor cupping on the front and my camber is at about -1.7
Norm Peterson
corner barstool sitter
RIP - You will be missed
Chances are it mostly wasn't the camber that ate your tires, but the toe that also changed. I just checked my car a couple of days ago and it's still at -1.9° ±0.05° on both sides, and the difference in tread depth, inside tread grooves vs outsides, is not measurable with the usual tread depth gauge that's graduated in 1/32nds of an inch.
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
No. I run -1.8 camber all freaking day without issues.
This. Your toe setting was FUBAR.
OP, you don't need to flip the mounts. You'll have a bit of extra negative camber, which really won't affect tire wear that much and will give you a bit more grip on corners.
Bad Horsie
Ocean NJ
Ok then... no flipping. thanks for the input
Will report back with my readings after an alignment check.
RocketcarX
Colorado
This makes a lot of sense, I believe I had the car realigned after reversing the mounts so I'm not certain that the mount reversal was the main reason my tires stopped wearing.
Bad Horsie
Ocean NJ
OK. I installed all my stuff and took it down the street for computerized alignment. numbers as follows:
I left the arrows on the mount pointing out
Camber:
front Left...-1.5
front right...-1.8
Caster:
L) 7.5
R) 7.1
Toe before L) 0.01
after L)-0.02
before R) 0.00
after R) 0.01
appears I didn't need to touch it. oh well 79 bucks got me some piece of mind and some numbers to start with.
Took for a ride around some clover leafs this afternoon
Wow!..Major improvement in handling ...Love it. no more mush mobile
