Mailbox Light...
tjm73
of Omicron Persei 8
Rush, NY
Ok electronics people.... need a little help with a switch. I have a mailbox that is about 500 feet from any appreciable kind of light and from about this time of year till spring it's hard to see inside the mailbox when you open it in the dark. This has bugged me for about 4 years now. I have a solution but I need help with the on/off switch. I know what I want it to do but I don't know the lingo to find it.
Below is a crude drawing of my simple circuit. For the switch, I want it to allow the light to turn on when the door opens, but turn the light off when the door is closed. The two 9V batteries are wired in series to deliver 18VDC to the 12-24VDC LED license plate light.
What switch will make this work?
oldVOR
Northern Virginia
I'd use a magnetic reed trigger switch. Mount the switch on the inside of the box with 3M DS tape and the magnet on the door with 3M DS tape. When closed, the magnet on the door will flip the contacts on the switch. The magnet and switch need to be roughly an 1/8" from each other when the door is in the closed position.
Why not just use the same switch used in car doors for the last 50 years to turn on the overhead light? A simple pressure switch available for free out of any junk car in the country. Or is that not fancy enough?
tjm73
of Omicron Persei 8
Rush, NY
That is a lot simpler. Didn't know such lights existed. Thanks.
Gabe
Whippled Coyote
I just use my phone's flashlight app to see in there.
tjm73
of Omicron Persei 8
Rush, NY
I just want to open the door after sundown and see whats in the mailbox. I don't want to hold a flashlight to do it.
Gabe
Whippled Coyote
Lol. I just never thought of putting a light in there.
My mailbox is just a regular size piece, sometimes the mail takes up most of the room in there.
bujeezus
Alabama
What about one of those push-to-turn on led lights 3m'ed to the inside of the door.
Macman45
Resident Geriatric
Atlanta / Bay Area
Pressure switch is fine, but would most likely require screwing into both the box and the door so there's no movement. 3M tape won't be enough, the force required to activated the plunger over time will tweak it's mount I'd imagine and cause it to slip off and stay activated all the time.
I like the magnetic reed switch for the simple fact that it doesn't even require physical contact. Like said above, 1/8". Line em up close and golden
