95ragtop
I am going to order some parts tonight and would like to know if you guys see if I am missing anything. I have a short block sitting on an engine stand that I would like to build over the winter and swap it next summer. I already have heads with upgraded valve springs. I plan on reusing my stock oil pan and I have an ACT twin disk to engage the tr6060. I am currently running 10 psi with a 3.4" pulley on a Novi 2200 and I have a smaller pulley and 10% overdrive crank pulley to make sure more air gets in.
Goals are around mid 500s on 93 and up to 700 on e85.
I plan on ordering:
stock mls head gasket/bolt kit (I know BruceH was fine with these)
full timing chain kit (is there any concern with the plastic tensioners)
ID1050 injectors (already have gt500 pumps and BAP)
Miscellaneous gaskets for the oil pan, crank pulley bolt
Do I need any sort of degree wheel to time the cams?
I plan on ordering:
