Dailon hall
can I go 1.75 in the rear with a 285/35 and a 10.5 wide wheel? I’m about to order a new setup and want to make sure.
this question is not clear.can I go 1.75 in the rear with a 285/35 and a 10.5 wide wheel? I’m about to order a new setup and want to make sure.
depends on if he's talking length or girth....That's a really small dildo!
1.75 in lower in the rear lolthis question is not clear.
" can I go 1.75 in the rear" ?? like a dildo? seriously dude, edit the post to be clear
Bare min of 51 mm required. You will have sidewalls sticking way out if a 45mm offset used.
A 54mm ET would be perfect. A 1.75" rear drop is a bunch. You require the rear tire to be tucked inboard of the fender. Screw up the ET..and you will kick yourself. At least on my 2010 GT. I believe the 05-09 cars are similar. The 10-12 cars all share the same body style.
