6r80 Swap Questions
Laga
Chicago
Due to me doing something I really shouldn’t have done. My 5r55s in my 2005 GT with E-Force SC has bought the farm. I do not want to go with a manual, so my options look like replacing with a beefed up 5r55s from Level10. Or, a 6r80 swap. A few questions about 6r80.
I know that you can get a separate controller for the trans. Since the car is tuned by Lito, does he shut off existing trans controls in tune?
Can I still use stock shifter with it?
I see conflicting info about HP limits on a new unit. Anybody know if it will handle 500RWHP without mods?
I’m aware driveshaft would have to be shortened, and new rear support added.
I would have to have a shop do most of the work because of health issues.
I have lost interest in the drag strip and do HPDE track days now. The week before I broke the trans, I got moved up from novice to intermediate. Great timing.
Any help would be appreciated.
Hamilton, ON, Canada
The 6R80 will handle 500RWHP all day long without mods. You'll need to get a two piece driveshaft from an 11-14 GT or a one piece aluminum driveshaft from the same years. Your stock shifter will work for the 6R80. Your ECM will need to be programmed over to a manual ECM strategy so it's not throwing codes about the 5r55s. You'll need a new transmission crossmember from said 11-14GT. I just switched over my 06 to the 6R80 and it cost me about 4K Canadian. The controller was the biggest cost at $1200 USD (Qucik 6 with external display). Here's a list of parts needed. https://docs.google.com/document/d/1sI54VhvIOUmMk1f8SH5BEN4Do47BEuonreCh8sVS1e4/edit?pli=1&tab=t.0
Laga
Chicago
Thanks for the info. Beyond expectations!!!!!!
Papiwaro
La Réunion
Hello friends,
Help. Help. I also made a 6R80 swap. I need help on my Mustang GT/CS 2007 4.6 3V. (all options) with :
• Auto box removed (5R55S)
• TCM deleted / beam cut
• Fully independent USShift Quick6-driven box
Objectives :
•⁠ ⁠Remove all DTCs related to transmission (P07xx)
•⁠ ⁠Disable auto box strategy in PCM
•⁠ ⁠remove fail-safe cooling
•⁠ ⁠restore normal communication with cluster (ODB, gauges)
I would like to switch the PCM to "manual gearbox" mode so that it no longer sends error code. I used Forscan but I couldn't figure out how to do it!
The good .ab file for Forscan would do I think.
Thank you in advance for your help.
If HPDE reliabilty is your primary goal, you need a manual conversion. Automatics will overheat open tracking.
