What to do about rear deck lid panel fading or peeling on 2013/2014 Mustangs??
Desmo900
You know - the glossy black panel between the taillights - it seems they all start to peel and look generally bad after awhile... Are you living with it, covering it with something, replacing it, painting it, what??
Gabe
Whippled Coyote
I replaced mine years ago with a painted-to-match RTR unit, then had a custom pony decal added on.
Steve Waters
The cheapest and easyest way would be to replace it with more vinyl. You can find it at any local sign shop. You can go back to the stock looking black or put any color they may have in stock if you want a different look. It may take a little time but it is relatively easy. Kind of like putting on window film. Or you could paint it like you said in your post. It just depends on your own capabilities.
Desmo900
The cheapest and easyest way would be to replace it with more vynle. You can find it at any local sign shop. You can go back to the stock looking black or put any color they may have in stock if you want a different look. It may take a little time but it is relatively easy. Kind of like putting on window film. Or you could paint it like you said in your post. It just depends on your own capabilities.
[emoji848] hmmm good ideas. I was thinking maybe have a tint shop cover it with their darkest tint. If that didn’t work, just have it painted either gloss black or body color.[emoji1743]‍[emoji3603]
kazman59
King of Kazmania
Kazmania
3M 1080 vinyl, can prolly find an appropriate sized piece on ebay or amazon.
WJBertrand
Thinking of doing some vinyl carbon fiber look wrap on it.
WJBertrand
I bought some high gloss carbon XPO vinyl from VViVD on Amazon for about $14 (12" x 60") piece. Going to give that a go. I think the high gloss will blend in better with the tail lights and be more subtle, closer to the OEM gloss appearance, than the flat or textured CF vinyl.
WJBertrand
I ended up replacing the panel a real carbon fiber one from True Fiber.
