Blew Up my 4.6 boosted 3v
Peyton0112
So I’ve been saving for a while and I just recently bought a 4.6 3v with a turbo with what I thought was built motor . Long story short it wasn’t and I blew the engine. I would rather sell the turbo and start from the ground up with a 5.0 but.., that’s not in the budget. I just want to know what the cheapest route is to get it back on the road. Or if I should sell the turbo, buy a used 4.6 engine and sell the car for what I can get out of it
A used engine will cost the least $$, and get it up & running the quickest.
eighty6gt
Get a used 3v from LKQ, open it up, get the recip. assy out, grab some 2018 F150 5.0 conrods (whatever the part number is now, go to tasca and get steve to help you, were boss 302, I assume the newest parts still fit,) and some new piston pin circlips to install the stock pistons on the 5.0 rods, send the entire mess to a machine shop to get it balanced, and boost it up to 800hp. I have the part numbers for the rod bolts you'll need to check bearing clearances somewhere. The rods come with some but you'll burn them tightening them down.
I used new mahle rings for stock bore. The end gaps were good. You can dingleberry hone the bores, I did not.
thread moved - the question is not a tech topic here.
As has been posted, a used 3v engine is quickest and simplest route
if your current block is usable, then you could have a shop like L&M Engines build you a new short block with it and keep the set up as is
Dino Dino Bambino
I have a red car
Cyprus
I blew the engine.
Many people say they "blew the engine" without actually blowing up the engine. Has yours grenaded or does it still run? If it's the latter, then it's still salvageable and you can rebuild it with forged rods/pistons. Otherwise, as others have suggested, your best bet is to buy a decent used 3V engine and rebuild that with forged rods/pistons instead.
Sactown
Sactown
Sacramento, CA
first thing I would do is figure out a budget, and what your expectations are, then stick to the plan
06redgt
Oswego, Illinois
https://www.tascaparts.com/oem-part...MIkcKQs-uR4AIVBDZpCh245g4wEAQYASABEgKarfD_BwE
