hockeygod
Selling my 2010 Mustang gt grabber blue track pack. Fully loaded with sync nav and mycolor dash guages.
Can take a serious buyer for a test drive in the warmer months if interested as my current tune runs terrible in cold temps.
Price 25,000
2010 Mustang gt Track pack
Motor and drivetrain:
-Stage 3 Brenspeed Hurricane B326 Long Block
-Inovator west 10% OD Pulley
-Tremec t56 magnum xl transmission
-Mustang GT Dyontech Drive Shaft 3.5
-Paxton 2200sl HO polished
-3.12 6 Groove Pulley Paxton Vortech 13-15 PSI
-steeda billet idler pulleys
-STEEDA BELT TENSIONER
-Mustang GT FRPP Intake Manifold
-Brisk 2 step colder spark plug black boot coil pack
-Deatsch Werks 78lb injectors
-Ford Racing Polished twin 62mm throttle body
-Mcleod RXT Twin Disc 26 Spline
-McLeod 8 Bolt Billet Steel Flywheel
-05-10 GT OEM Ford Slave Cylinder Exedy
-Pilot Bearing 96-2014 Mustang, Gt 500, Boss
-3.73 rear gears
-FRPP Performance Cooling Fan
-160 degree thermostat
-Snow performance new stage 2 methanol injection 210 kit
-VMP Blow-through 75MM MAF housing and HPX MAF sensor
-AFM -Tial Q 50mm BOV
-Diablo sport maf extender
-Cfm performance billet oil cap breather
-K&N breathers for both valve covers
-Upr billet catch can.
-Moroso sealed battery box for trunk
-Ford racing dual fuel pumps with upgraded harness
-Dual aeroforce intercepotor gauges with oil pressure sensor and wideband kit
Exhaust:
Varex x force mufflers
Kooks longtube headers with catted x pipe
New 3” stainless exhaust tubing to mufflers
Suspension:
-BMR adjustable upper control arm
-Steeda rear Lower control arms
-Ford racing front a Arms
-BMR adjustable panhard bar
-BMR front and rear sway bars
-BMR upper control arm mount
-BMR TUBULAR K MEMBER W/
MOTOR MOUNTS BMR
-BMR Radiator Support with Sway Bar Mount
-BMR Chassis Brace/Radiator Support
-Steeda hd caster camber plates
-Koni orange struts and shocks with Steeda lowering springs
Brakes:
Gt500 Brembo brake upgrade with stainless brake lines.
Dressup:
-Carbon fiber black mamba II hood
-Kenwood 5 channel and 2 channel amp with custom subwoofer box alpine type S Subwoofer. Polk components in front doors with alpine 6x8 type r’s in rear
-STAINLESS SHOW WORKS POLISHED RADIATOR COVER
-Boss 392 front fascia with splitter
-blackout rear deck lid
-2013 Tail lights
-2 sets of headlights- stock 2010 and a set of 2013 not installed yet.
-RTR tech 7 lightweight rims and tires.
Less than 1k miles on the Motor, Tranny, Tires, Rims, Suspension, Brakes.
Dyno'd at 711rwhp on mustang dyno.
Price 25,000
-3.73 rear gears
Exhaust:
Suspension:
MOTOR MOUNTS BMR
Brakes:
Dressup:
-2013 Tail lights
