Jamie A
Yea i know its a refabricated continental pcm unit.
I would like to see a similar list for the guys that live in CA and have to be CARB legal.
May have missed it, but how are people handling HVAC, lights and such? Do you reposition the factory PCM or will that stuff work without the PCM?
I have figured out how to get the speedo and oil preassure gauge to work again.
Only issue now is how to get coolant temp communication on instrument cluster?
Has anyone found solutions?
Gen 1 also has 3 pcm connectors. As for the can bus, maybe you got the two wires reversed? They are marked + and - and will only communicate one way.Ok yeah gen 1 and gen 2 ford control pack are very different. The pcms are even different. Gen 1 has 3 pcm plugs and gen 2 has only 2 plugs for pcm
I did not use a converter box, just wired up the 2 wire oss sensor by connecting one wire to the signal return wire and grounding the other wire from the oss. The other two wires on the coyote pcm are +5v and 5v return (not used) Then I dialed in the speedo with gear ratio and revs/mile settings. These are NOT actual to the car, I had to find what worked.
