re: Coverlay Door Panel Inserts
scrappydoo1888
Ottawa Canada
Hey boys! Has anyone purchased these door panel inserts? I don't feel like re-gluing my vinyl again on my 2005 Vert. I'm thinking this might be the easiest/cost effective alternative.
Thanks,
  • Made From Durable ABS Plastic And Vacuum Molded For Perfect Fit
  • Easily Installs In Minutes
  • Sold In Pairs
  • Will Not Crack Under Extreme Temperatures
  • Coverlay Limited Lifetime Warranty
  • Made To Order Shipped Within 48-72 Hours
  • Generic Colors Available
  • Made In the USA
Product Details
Medium Gray - Front Only - Silicone Included - Will Not Fit Solid Plastic Inserts - Sold In Pairs
Racer47
Doesn't have much to say
SE Wis
I've looked at these several times but never bought them. I agree that it is probably the best solution but I haven't done it yet.
If you buy them, let us know what you think.
scrappydoo1888
Ottawa Canada
I just ordered a set today in slate gray so once I receive and install them I'll take pics and give you my thoughts. I might also do some welting in red to finish the look off.
08MustangDude
Resident Fuktard
I re-glued mine, but this heat messed them up again... That is
what causes the problem in the first place...
fdjizm
Drag Queen
I re-glued mine and that didn't work so I have staples painted black all around the edges of the mofo. this looks promising though.
nbk13nw
Yeah, i removed, cleaned and re-glued. It lasted about 3 years before it started coming loose again. Ended up uaing some piping to hold it in place. Piping works but i may go ahead and order a set to see if that looks and works better.
08MustangDude
Resident Fuktard
I used 3M Super 77, and for the most part, that held. The top parts
are falling out, they need gone over... I need to tape off the door
and coat that parameter better. Everything below that held with the
Super 77.
This, without cleaning the old crap off, I doused the whole area, and the material,
then rolled it back on. Could not fully get the parameter where it pushes into the
panel.. Other than that, the bulk of it is still in place. Heat does soften and goo up
the spray, so you need this good stuff to prevent that. The Super 77 is less prone
to sag under heat.
nbk13nw
How are they attached? Could not find any info in the site.
N2STC
I am going to try GE silicone (AKA RTV) on my '06. I have good luck with it in many places. The side of the shifter also needs it.
Racer47
SE Wis
RTV is thick and may end up being lumpy. The spray one adhesives lay on thin and even. I would use that.
There was a thread a long time ago that seems to show a correlation between the amount of leather / interior cleaner used and the speed of the lining coming off. The cleaners seem to seep into the material and the glue comes off.
My point is, I don't think its necessarily the adhesives fault, so I personally would not try rtv.
JeremyH
3V Fuel Guru
Virginia Beach
My 07 that I optioned without the iup, came with hard plastic door trim covers from the factory. All I did was add the welt trim. It's a better match for texture looks like than these aftermarket ones. I'm sure you can find them cheap from a yard or part out car.
Racer47
SE Wis
Thats a good idea, never thought it. (ps I still haven't figured out my issue, been busy with work but I'll find it, i never give up)
MADGT
USA
That DOES looks nice...I just re-applied adhesive to my driver side..it came off after 13 yrs...not bad, but annoying.
