Fitting a 460 BBF and C-6 trans into an s197....the "lower buck" way
M7w7j7
so weird question do you have a facebook because i am in the process of doing the same swap and i also run a group on facebook devoted to this swap and your info would help alot
RocketcarX
95% of my weight is fuel
Colorado
What is the name of the group?
Bardstown, KY
Bardstown, KY
Looks like I will re-post the links. Hopefully the pics will not disappear again...
Bardstown, KY
This is why Hooker 460 Fox Swap headers will not fit on the driver's side. There is not enough room for the # 8 tube to snake between the steering shaft and the frame rail
Bardstown, KY
Plenty of room on the passenger side for the Fox 460 Hooker Header. Bottom pics shows 74-78 Ford LTD exhaust manifolds installed both sides ( for the super low buck guys)
Bardstown, KY
These are the engine mounts in the rough-in stage. I bought the car with a AJE k-member already installed so making the mounts was easy once I located the block where I wanted it
My engine sits further to the rear than those guys that are using the AJE k-member with the AJE mounts. I did this this so I could run a full size mechanical water pump in conjunction with the factory s197 fan. ( keep the costs down)
Bardstown, KY
C-6 transmission is big but fits the s197 tunnel ( barely)
I did have to massage the right side floor area next to the servo housing. Barely clears the hump on the left side where the crossmember bolts up
Bardstown, KY
I made my own trans crossmember because I needed it to be adjustable for 3 different types of transmissions I will use in the car.
Plus I wanted it to be the attachment point for the new 20 dollar driveshaft loop
Bardstown, KY
14 x 3 Moroso Air cleaner clears the hood blanket (barely) The Edelbrock Torker II intake is what I was using in the pics. There is a video in post # 19
jsimmonstx
Comal County, TX
I recommend that you use a cowl hood. If that motor bounces around for any reason, you're gonna end up with dimples in the stock hood. It would also allow you to use a taller filter element (more air is a "good thing" (TM).
