California special fogs.... Question....
Jgt58
So I did a search and didn't see the answer to my question so to the s197 gurus it goes...
I have a 14 gt with grille lights. My question is can you run cs fogs at the same time as the GT fogs?
WJBertrand
Yeah, I’m doing it. Just used one of the wires from the grill fogs to trigger a relay that connects the CS fogs to the battery.
WJBertrand
check your state laws, some states only allow 4 lights on at once.
This is a good point. I may have incorrectly interpreted the OP's post as a technical question. I'm not sure about the legality, but in the 4 years or so since I installed and wired the CS fogs this way, I've not had a second look from any LEOs.
Jgt58
No your right. I could care less about the legality of it. Just like No cat law [emoji13]
JEWC_Motorsports
S197 Junkie
I care about the visual legalities, i dont want a reason to get pulled over. Once you are pulled over they can then do a full inspection and for me id be screwed.
Jgt58
Thank God we don't have emissions here
scramblr
New Braunfels, Texas
Seriously? How many times have you seen that happen around here? I've been pulled over 3-4 times in the last 7 years and aside from the speeding ticket I never get out of, they always give me a warning for no front plate and a clear plate cover in the rear. Not once have they commented on anything else with the car, and they know it's not stock. Hope I keep getting lucky 'cause I know I'll get pulled over again. :whymewhyme:
JEWC_Motorsports
S197 Junkie
Wanna know how many times ive been pulled over for my exhaust? lol my last ticket was 280 because of a noise ordinance. Thankfully its not considered a moving violation or my cdl would be screwed.
LDC2335
I thought about doing this with a 2 way toggle switch. Or run the bumper fogs with the lows and the grill lights aimed up with the brights. Or, just running them all at once...Still deciding.
Capgard
Phoenix metro west valley
Jgt68, curious... do you already have the valence fog lights?
I have a set, orig Ford, not used in the box. Also have the LED light conversion bulb kit. New in box.
Both from AM. I'd list it but can't yet as I haven't passed the Classified algorithm.
