Check engine light
Jerry Donnell
Good to know on the NTK/NGK parts, thanks. I had an issue finding the right sensor, apparently ford changed midstream in manufacturing, the sensors changed in March of 2011, mine was built in December 2010, so Leary about buying online and having the wrong one sent to me
Jerry Donnell
Pins on the male plug are fine, I checked them several times while replacing the sensor
Sounds like you are going to the dealership then.
Rockauto sensors cost me $45 ish each.
Jerry Donnell
Are the voltage parameters different on lower end sensors? That would make sense to me for it throwing a false code. Are the parameters tighter on NTK and Motorcraft sensors? I found a motorcraft sensor on rock auto that is the right one, but already spent money for the other two sensors and don’t want to spend if it’s another issue. Jgt58?
Jgt58
Always if you can go with motorcraft replacement. Let me verify via my parts lookup. I'll screenshot
Jgt58
First I want to say I was incorrect. Bosch is the actual or manufacturer. Here your correct part numbers.
Jerry Donnell
No just bank 2, but that’s the one the code is coming from via the code reader
Jerry Donnell
That’s what I thought, I exchanged it yesterday for another new one and installed. I thought I had it beat until I drove it both highway and city for about an hour with no light. Let it cool for about two hours and started it in the driveway. After about a minute idling the CEL lit back up and is showing the same code
I would change the other side too. I only had the code on one side, but changed them both.
Or, swap the two upstream sensors and see what happens.
Jgt58
Juice is correct. Next step would be to swap out the sensors and see if the code jumps sides.
If it doesn't it may be the connector. I'll dig up the motorcraft number.
Jgt58
Here ya go on the connectors
Jerry Donnell
I’m also assuming both upstreams are the same, if I switch them and the code disappears, is there an issue with just leaving it alone?
Jgt58
My prediction is that code stays the same and that it's a wiring issue
