theRedStorm
- Joined
- Aug 30, 2015
- Posts
- 150
- Reaction score
- 21
Anyone know where I can find these? I can't find em on ebay anymore
Lol people say wheel spacers aren't safe lolYes they are very hard to find. I purchased mine from a guy in NC who made aircraft parts. They do work but some people think they are not safe. It saves a ton of time fooling with the axles and rear end. They were not made in China. I found my Ebay receipt and he is still listed in Ebay. I sent him a message.
What would be the dangers other than cheap material leading to brackets breaking?
https://www.blowfishracing.com/brak...ar-caliper-mount-plates-138-gt500-rotors.html
I'm confident that the only function of the larger rotors on the 500 is so that on track you can absorb and reject enough heat that the rear brakes don't completely go away.
I would never bother on a street driven car.
YMMV.
Is about $10 worth of aluminum machining and fasteners, maybe I should make some ... nah.
Aircraft aluminum is 7075 or 2024 alloy, not 6061-T6. 7075 is stupid expensive, but at least it's 70 ksi yield strength. 2024 has 2% copper in it, and can't be welded...and is only 42-44 ksi yield. 6061-T6 is only 40 ksi yield. 6063-T832 is only 39 ksi yield.They say the brackets are made of Aircraft aluminum. In doing my Mustang, I found out my low mileage and only used every so often Mustang had stuck calipers in the rear. Maybe that was the reason I decided to install a big brake system all the way around. This makes me think the Mustang would brake OK even if the back calipers were missing all together.
I run a job shop... hehehehe... was meaning to say I could sell them.It's the setup time and equipment that makes them worth much more.
And that’s why I don’t plan on this for my car. Just a street car so doesn’t need it. The rear caliper wouldn’t be as hot as it has a larger rotor to dissipate the heat.https://www.blowfishracing.com/brak...ar-caliper-mount-plates-138-gt500-rotors.html
YMMV.
Two types of brackets available. The Ford made ones all one piece so you must remove the axles. Then the Aluminum "add on" brackets where you don't touch the axles. Because my Mustang only gets a few 1000 miles a year of use, the back calipers froze from sitting. So for years, I was just using the front calipers. After a few test drives in new Camaro V8s including a ZL-1, I decided up redo the Mustang brakes with a big brake kit. Most of the money is in the front. The back brakes are rather cheap at Rockauto. So everything was done as a matter of course. After several bleeds, everything is new and the brakes are wonderful.And that’s why I don’t plan on this for my car. Just a street car so doesn’t need it. The rear caliper wouldn’t be as hot as it has a larger rotor to dissipate the heat.
those blowfish brackets, are they the ones you have to pull the rear axles to install like the Ford ones?
I just want em because of looks. Filling out the rear wheel does look good!https://www.blowfishracing.com/brak...ar-caliper-mount-plates-138-gt500-rotors.html
YMMV.
I don't track the car. (maybe drag strip run once or twice a year). Only concern of mine is safety. But I don't think that should be THAT big of a concern with the 7075 aluminum
I use the aluminum "add-ons." They have always worked fine, but I don't track the car either.
Admittedly, I did it for looks. With 20" rims, the smaller rotors look goofy. Even the larger GT500 rotors could stand to be bigger from an aesthetic standpoint.
As I said, you will not notice that much in the rear even if the rear calipers were missing. Mine were frozen. The race only 13.8 inch rotors are very cheap. I got mine at RockAuto for $15 each. They have no RUST protection and will rust bad at the first wash. I replaced them with the same but with rust protection for $35 each.
