DieHarder
- Joined
- Nov 9, 2019
- Posts
- 1,851
- Reaction score
- 1,073
Follow up. What did you about that brake line that was nicked?
Have you been able to seal all of the grommets/windshield/pinch welds?
Before you button it back up Highly recommend checking down inside the rear seat side panel walls on each side for rust (remove seat belt tensioners - only one bolt) since you've got it apart.
Also the spare was used enough that the tread is worn down and it was flat.
