ghunt81
New parts on old junk!
I did JBA long tubes years ago, first the ceramic coated then found a great deal on 304SS versions so I pulled out the ceramics and put those in.
Install is time consuming but not difficult. You do have to raise and support the engine while doing the job since the engine mounts have to come out. By far the biggest pain is removing the stock manifolds because everything is rusty. After that it's a breeze. Be aware it will be much louder even with the high flow cats.
BTW if you do it get stage 8 locking fasteners, they aren't that expensive and you won't have to worry about the header bolts. Also make sure you get a multi-layer steel or aluminum gasket, I have run both and both are good (some headers still come with crappy paper gaskets).
