Max70
- Joined
- May 30, 2021
- Posts
- 57
- Reaction score
- 5
Hello guys and gals, I need some help on certain specs about suspensions, shocks and springs.
I live in Europe so getting things is already hard, frustrating and very expensive over here, so please bare with me if I'm a little insisting on this issue. I also tried the search engine before posting but could not find any related topic (maybe I used wrong keywords)
So my issue is the following, I have a 2006 V6 4.0 which when I purchased it seems it was already modified aesthetically, but also had the suspensions altered, so I found out that it has KONI orange struts on the front with blue springs which are I guess 1.5" lower and the same is for the rear with the springs. I only guessed they are lowering springs because there is only like 13 cms (approx 5" ) from the pinch rail to the ground. the ride is also hard, you can feel every damage on the road and when I try to push down the car at the front fender, it doesn't move at all (not even half an inch).
My problem is that since it came with big 20" Shelby wheels which are also beautiful and do not want to change them, they are also wide and are exactly in line with the fender arch.
Now when I went to a garage to check about new shocks or coilovers the seller asked me if I know the height of the car from ground to wheel arches with stock suspensions and stock wheels, so he can calculate the difference from stock to what I have now and can adapt new suspensions (either struts & springs or coil overs.
Is there anyone that can give me this information or lead me toa source?>
I need the following measurements, always with all parts stock (wheels and suspensions).
I kindly need all the assistance I can get.
THANKS!!
- Front, fender arch to ground
- Rear, fender arch to ground
- wheel external diameter (front and rear)
- measurement from middle of wheel the fender arch (front and back)
THANKS!!
