Great solution, you should do a write up, or make/sell a kit for DIY.My car did this also. I removed the trigger signals (high and low speed trigger from the computer) from the fuse box and used them to trigger a Leash electronics dual 70 amp relay.
Basically re-wired the fan circuit outside the stock fuse box.
It’s not a very difficult task, I could try to get together step by step directions, but I am out of town this week. It would probably be this weekend before I could do it. You’d have to get the relay setup ordered too. Leash can take a while sometimesMan, that’s above my pay grade. . I don’t have experience with anything but replacing stock stuff, but I guess you didn’t either until you did.
www.leashelectronics.com
Thanks for posting this link!![]()
Dual 70 Amp Relay Module
Dual 70 Amp Relay Module. Features: 2 industrial 70 amp heavy duty relays. 1/4" main battery input stud, 2 #10 outputs studs and inputs use female fork crimp terminals. Uses heavy duty J-case automotive fuses. Can be setup for positive or negative triggering. Has led's to diagnose operation...www.leashelectronics.com
As I read through this I wondered why no one had mentioned Casey. He makes top notch wiring solutions for our cars.I have the FPP fan upgrade and the Wire Everything kit.
They now make a HI-Amp Resistor Pack Delete Harness.
