Windy_3V
So I was driving home from work today and noticed an unsettling noise coming from the underside of the car. I had the music cranked and I was able to just catch it through the music. I stopped immediately and got out to check over the car but didn’t find anything and proceeded to drive home since I was only a mile away.
Best way I can describe it is a hollow rattling or knocking. Only happens when the car is in gear accelerating or decelerating. It’s not necessarily rhythmic but the noise does increase under higher load and gets faster at higher speeds. If I put it in neutral while rolling it goes away. It’s not present while idling at a stop or revving the engine at any rpm either.
I doubt it’s the motor but I could be wrong. I just changed my oil a few hundred miles ago and checked it when I pulled over and it’s fine. I suspect it’s transmission or drivetrain related since they’re pretty tired and most likely on the way out. Still has the stock 5-speed manual with 206k miles with a McLeod RXT twin disc clutch and MGW short throw which have been in the car since I bought it about 3 years ago (Yes I know I should probably replace my clutch lol)
Just wanted to see if anyone had a similar issue and/or can point me in the right direction of a possible issue. Haven’t really had a chance to get a good look at everything since it was already dark out so I’ll have to wait till tomorrow.
Might be my final kick in the butt to motivate me to do that TR-6060 swap I’ve been wanting to do
