Alternator went out
Hollowdweller
Looks like I’m gonna have to replace the alternator on my 2006 Roush….which one should I get? Prob need the 200amp….adding stereo system.
Hollowdweller
I jumped on an open box SR Performance 200amp from AM for $160…anyone ran one of those?
Blue03Cobra
Baton Rouge, La.
Hollowdweller
I have one in a box, ready to go on. Make sure you upgrade the alternator-to-battery wire, for a 200A. Engine bay fires are no joke. This is the one I went with:
Yeah I’ve been looking at that. I’ve already ran a 4awg from the alt to the batt when I had the motor out but noticed that ones fused. I didn’t fuse the one I did bcz it wasn’t fused from the factory. I don’t really understand the fuse location with that kit, I’d think it’d be closer to the Alt than the battery…? Still been thinking about it, used some power wire from my sound system install, dunno if it’s a different type of wire..?
Hollowdweller
I used a 4awg wire designed to power amplifiers. I’m assuming those little strands of copper couldn’t handle it. Maybe it was the heat and that type of wire. I reinstalled the factory wire with the stock alternator and am now getting 13v at idle. Figure I’ll order the wire upgrade kit from American Muscle and throw the new alternator in in a couple of weeks
DieHarder
Buy a new set of OEM battery cables. The fact that you're only seeing 13vdc at idle tells you they need to be replaced. You can still get them on feebay and perhaps some dealers but they're becoming scarce these days.
JC SSP
FL
I use a custom 200AMP High Output Alternator with 4-gauge power wire with in-line 250AMP fuse.
JC SSP
FL
14.1V at Idle and 13.9V at load (A/C, flashers, headlights on, etc.).
DieHarder
On the lower end of acceptable. Should be 14.5 vdc or better. You can try adding a ground cable from a mounting bolt for the alternator to the passenger strut ground. That will ensure ground is the same throughout the system. Due to age/corrosion it's likely that your battery cables/harness need replacing.
You can still get them on feebay:
Dino Dino Bambino
I have a red car
Cyprus
On the lower end of acceptable. Should be 14.5 vdc or better.[/URL]
The ambient temperature plays a part. In colder weather, the voltage will be higher because although the current stays the same, the resistance increases. The converse applies on hot summer days.
Therefore:
Is fine at this time of the year.
That said, measure the voltage between the alternator casing and the passenger side strut tower grounding point. If you get a measurable reading, add a grounding cable between the two.
JC SSP
FL
I am in Miami, FL always hot & humid. LOL
FYI My Audi is 13.8-14.2 and its relatively new. Wifes' 23' 5.7 R/T Durango is always 14.2-14.5 regardless, if at idle or under load, but that thing has a tone of electronics...
I will be keeping my eye on it and even considering buy a new battery harness, but other projects are ahead of this one. ;)
Shane361
Charleston, SC
When using wire use OFC as it is the best. There is some very cheap wire out there. Generally if it flexes easy it is better than wire that is more stiff. Also no need to remove stock wire, just add to it. Also make it easier when going back to stock if needed.
I believe the factory alternator wire has a fusible link but I don’t know the rating. Also #4 cable is not rated for 200 amps.
# 4 ga wire is no way, shape or form, rated for 200 amps.... not even if it had 225 Deg C insulation.
My 2010 GT auto is 14.75 vdc across the battery terminals with eng on, in idle. It doesn't drop at all with halogen lights on, foglamps, oem stereo, etc.
Laga
Chicago
On the lower end of acceptable. Should be 14.5 vdc or better. You can try adding a ground cable from a mounting bolt for the alternator to the passenger strut ground. That will ensure ground is the same throughout the system. Due to age/corrosion it's likely that your battery cables/harness needs replacing.
Why not from alternator bolt to battery post?
DieHarder
This is ideal. The majority of our cars however are going on 15 - 20 yrs now and in many of them the inherent resistance has increased in the battery and ground cables due to corrosion & sulfates (that green patina). You often see this in the SJB as well due to water intrusion. Higher resistance in the cables/connectors (usually manifests as heat) creates a higher voltage drop across those elements meaning there's less voltage available for other circuit elements which we often measure as lower overall circuit output voltage across the entire system (positive to negative side of the battery).
DieHarder
You certainly could but the system ground is the frame and it's usually easier to run an extra ground from one of the alternator mounting bolts (i.e. same as case ground for the alternator) to the passenger strut tower ground (shown below) which is the same point that the negative lead of the battery is connected to.
