AdamBorz
So bought this car used and it had a stumble upon acceleration, found couple bad spark plugs, changed out 02 sensors etc. slightly better, but the stumble remained.
I bought HP tuning software and the credits for my car, pretty neat and I was able to view the tune in the car.
Contacted Lito (who’s been great) and he told me he doesn’t use HP tuner on these older Fords, he uses SCT. Well my car came with a SCTX3 so no issues; but still disappointing.
He gave me a base tune which has the throttle way better than it was but now car is going way rich after WOT runs and staying there until I either restart car or rev the engine repeatedly for a bit then the wideband starts reading again.
Lito says the narrowbands are showing lean, and he thinks the wideband I have might be reading wrong.
I can still log use HP scanner and it shows my FPDC jump to 75% when this happens. I can smell gas too.
I get that it would take a second or 2 to purge off fuel in a returnless system but I can continually drive around without Rev’ing engine and the wideband will stay pegged max rich and the car stumbles all over itself and smells of fuel.
After I installed Litos tune I found my BAP wasn’t working so fixed that, so maybe now that the BAP is working is the reason I never saw car do this before.
Car would run lean when accelerating (according to WB) hence I contacted Lito cause even setting my OL fuel to command .78 lambda I was going lean with 60 psi injectors etc.
Anyhow, am wondering if anybody else ever experienced this? I’m thinking of putting the original tune back in the car and running it to see if it happens with that tune.
Car has gt500 twin fuel pumps, 2 FPDMs etc so appears to be hooked up correctly.
I made Lito a video he wanted to see what wideband was reading. Gauge LED is not working right so have purchased new AEM wideband kit just haven’t gotten it installed yet.
If you zoom in on the wideband (pillar location) you can see it flick briefly lean when I floor it, then return to center then slowly creep rich. Lito said to accelerate then let off gas don’t shift to see what it does (I let motor wind down first pull) and it goes to 10:1.
Cool note, if you zoom in on boost gauge you can see how fast the KB brings on the boost. It actually pegs the gauge off the limiter stop before settling at 18 psi.
Haven’t had a chance to install the new wideband and gauge, and sorry about my head getting in the shot, I keep leaning forward to look in the side view mirror.
