Alcatraz1862
Hi. I don't even know if I can surprise anyone here, but I still want to share what I've found and what I've been struggling with for 2 years now.
As you know, the market is full of variations of these panels.
These are the ones that I've seen and tried in the installation
This is the very first panel that I installed
I've only seen this option, but I didn't dare install it. He was expensive
And the last option is what I want to stop at
At first, I wasn't chasing the look, but rather the functionality and normal synchronization of the system with the car.
However, over time, the eye began to find fault with the appearance .
And I started looking for the most suitable option.
And I stopped at the one in the last photo . The difference between the other two similar panels is that the latter option has an additional display about the current climate control settings.
But the following problems are already an adaptation in the car system.
And for the most part, the problems are in the Canbus decoder that comes bundled with these systems.
This is the very first decoder included with the first panel. As for me, it is the most adapted to the car and even all the buttons on the steering wheel are configured with it, even those that are designed for sync.
Unfortunately, in the last panel, I couldn't adjust these buttons due to the lack of an application to adjust the buttons running on the car tire, but I'm trying to find a way to fix this.
Additionally, there is another problem with the last panel, which is that when connected to the car 's bus, it sends a signal to the dashboard and converts the measurements of the on-board system from metric to imperial and does not allow it to be changed until the panel is disconnected.
Here the problem lies specifically in the Canbus firmware, which is supplied by the manufacturer of the decoder, and so far it has also not been possible to get help from sellers in this direction.
In all other cases, the following problems were encountered with other panels (except the first one) :1) The backlight of the buttons on the car tire on the panel did not turn on (also firmware) 2)The screen did not switch to reverse mode and did not turn on the camera 3)And the heating of the glass mirrors did not turn on . All three problems were encountered on the Teyes panel and its first counterpart, which came without an additional climate display.
That 's all for now. If you are interested and have any questions, I am ready to share.
