ryanoneill
I've been chasing an issue on my 2014 GT for a while now and I'm hoping someone here has seen something similar.
It started about a year ago when I was driving and randomly got a "Service AdvanceTrac" message and the power steering cut out for a few seconds, then everything came back. At the time I replaced a 100A fuse and the issue completely went away, so I thought it was solved.
Fast forward to recently and the problem came back, but now it's way more aggressive and unpredictable. Since then I've had a new battery and multiple steering racks swapped in. My mechanic checked the grounds and cleaned the connections when doing the swaps. One of the racks actually felt noticeably better—tighter and more responsive—but even with that one the issue still came back, which makes me think the rack itself isn't the root cause.
After already swapping two racks, I also took it to Ford. They ran their pinpoint test and said it was the rack and couldn't find any voltage issues, but after they cleared the codes the car actually drove fine for a while under normal conditions, which made it even more confusing.
The strange part is the pattern. The car drives completely fine under normal conditions when codes have been cleared or right after a new rack is swapped in. I dropped it off with my mechanic and he had it for a few days, drove it constantly, and couldn't get it to happen once. As soon as I got the car back, I did a few hard pulls and broke traction a couple times, and right after that the power steering and AdvanceTrac shut off instantly.
At this point it seems like it only happens under load, especially during hard acceleration or when the tires break loose. I've noticed that sometimes the power steering will briefly come back while driving and then cut out again.
Right now I'm trying to figure out if this is a voltage issue under load, a bad ground or wiring problem, or a steering angle sensor or module issue.
Before I keep throwing parts at it, I wanted to see if anyone has had power steering and AdvanceTrac fail specifically under load like this. Any ideas or things I should check would be a huge help.
