Bump Stop Advice
Billyjack
North Carolina
Just Installed new rear bump stops. The old ones were starting to disintegrate. My 05 GT is lowered about an 1 inch in the rear, maybe a little more. It looks like the factory bumps stops at some point were rubbing the frame. There were orange foam marks/residue on the frame. After Installing the new bumps stops I only have 1 inch of clearance. Do I need to cut the first section of the bump stop nub off?? I would think I would need more clearance than 1 inch.
JC SSP
FL
Yeah I cut mine to the first collar but only after driving it and seeing and feeling if they were touching. I am 1” lowered on Ford “P” springs.
StockishS197
Houston
With my Eibach springs, I originally had the ford performance joust bump stops, however I noticed they were basically resting on the perch and the rear would feel a bit odd over bumps, so I cut mine down to the square end and it rides much better. Even over big bumps, no issues bottoming out
Kev555
Ireland
Seems to be a common issue on the rear of S197,s finding that sweet spot with bigger wheels. I had the same issue with coils overs, had to run them stiffer than I would like
Keshy
Detroit, Michigan
On your lowered '05 GT, 1" of clearance with the new bump stops is pretty tight, especially if the old ones were already rubbing the frame.
Reddawg
North Florida
Following. I think I need to go check mine as well. It’s lowered (bought it that way) but I haven’t put eyes on the bump stops yet.
Billyjack
North Carolina
So, I cut the first nub off the bump stop. Got the car down on the ground with my new tires finally! Took it for a 10 mile test ride and it seems good. I didn't feel any bottoming out at all. I'll have to take it on a longer ride to be sure though. I have about a 1 1/4 inch clearance. If I need to, I guess I can always cut the next section off.
Reddawg
North Florida
What brand did you get?
Billyjack
North Carolina
I bought them from Amazon. M5570A 4Pcs Front and Rear Bump Stops for Ford Mustang 2005-2012 Replace M-5570-A, Jounce Bumper Kit. They were only $13.99 and they came with everything (bracket and bolts) There are a few kits on there, and they all look the same to me. I looked around for a while because I really didn't want yellow, but that's the only color I could find. The quality seems just fine.
