Here is a link to Ridetechs page on 460 and Godzilla mounts. Granted these are to bolt up to the Ridetech subframe/crossmember, but that part is identical. The plate that bolts to the engines is different. You can see just how much different.
They also have a small block Ford mount which is different from those two.
But you can see the block mount differences.
And that's before figuring out where exactly on the block they are located.
NEW | Godzilla & Big Block Ford Motor Mounts for Ridetech IFS Equipped F-100s - Ridetech https://share.google/6AoPcj8OOE17JhmTP
I can only imagine an 8 pot with those
