Gauge poll how many do you run?
How many guages do you have?
  • None, not needed.
    Votes: 6 18.2%
  • 1
    Votes: 0 0.0%
  • 2
    Votes: 10 30.3%
  • 3+ I gotta know whats goin on!!!!
    Votes: 17 51.5%
  • Total voters
    33
Vapor08gt
Huntsville, Texas
Just like the title says guys and gals, how many gauges do you run in your car? Working on a new project and I want to see what everyone uses in their cars.
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Four for me... AFR, boost, water temp and fuel pressure.
94tbird
4R70W FTMFW
A/F
Fuel Pressure
Water Temp
Oil Pressure
Aeroforce Twin Gauges, each showing 2 items - Fuel Pump DC, Ignition Timing, Ambient Temp, and Voltage
Charlie Sheen
Armed and Hammered
Infernum ubi sum
Aeroforce single reading tranny temp and IAT (warning light set for tranny temp >210), AFR, fuel pressure, vac/boost, water temp w/sender at crossover.
Hawgman
THE fucking bad guy
Same as everyone else.. a/f, boost/vac, fuel pressure, and water temp.
I have two Aeroforce so I can monitor 4 readings....
DirtyDogOfTheDesert
Canada/Yemen
3 in the A-pillar pod....
AFR
Vac/Boost
Fuel Pressure
And 3 in the center dash pod...
Twin Aeroforce gauges
Flow Meter for Water/Meth kit.
YLWNOR
ProCharged
Connecticut
4 here
oil gauge in the vent enclosure
Fuel Pressure / Wide Band / Boost on the middle dash
retfr8flyr
The Old One
Providence Forge, VA
As an old pilot I am a little nuts about knowing what is going on so I have 8 gauges. I have water temp, trans temp, oil pressure, fuel pressure, boost pressure, wideband A/F and left and right bank egt.
Earl
05stroker
Never enough power guy!
Bullard Tx.
3+ . I have a 3 gauge piilar pod and a 3 gauge dash pod and even one in between the ac vents . I will even have one in the console soon for the N20 . Some have refurred to it as a 747 , but what the hell ...
bigwilly43729
I do stupid shit, a lot
Oklahoma: Not terrible
3. Oil Pressure, oil temp, tranny temp. Will be adding a nitrous gauge and possibly a A/F and fuel pressure. The oil temp gauge will be going away if everything works out.
DirtyDogOfTheDesert
Canada/Yemen
Earl
What temp's do you see on the EGT gauges, at cruise, and what max temp when you're getting on it?
retfr8flyr
The Old One
Loafing along at 70 mph the temps run around 800. I haven't run over 10# of boost as the car has not been on the dyno yet but at 10# the temps increase to around 1200. I have my temp probes at the collector just before the turbo.
Earl
