screamingstang
- Joined
- Oct 30, 2008
- Posts
- 976
- Reaction score
- 3
If you are drag racing your new Mustang and don't need a front sway bar, our crossmember can save an additional 11 lbs. off the front end. The factory radiator crossmember is built overly strong because it must also support the additional loads of the front sway bar. With the swaybar removed, the crossmember only needs to support the weight of the radiator. Our lightweight crossmember only weighs 5.5 lbs. as compared the OE 16.5 lbs. Combined with sway bar removal, expect a 26.5 Lb. weight reduction!
if you guys drag race this is a must!
man the car feels hella better...i can feel the front end pick up....
some nince wrinkle walls...and damn ill be doing wheelies...lol:uzi:
