Combined 15" wheel Fitment Thread
gijosh28
Bad Penny
Savannah, GA
Man that car is starting to really come together with the rims and that hood. The rears definately need to be a bit taller.
Chris06GT
Dragging LS A..
Alabama
A 28" in back and a 27" in front will look good with some BMR springs or Pro Kit
xtweakerx
Get SOME!
Palm Beach, FL
did everyone else also put weights on their wheels w/ the rear ET Streets? for some reason both my rear tires required a decent amount of weight to balance properly, it was even though the amount of weight for both rear tires, the et fronts were nearly perfect not requiring much weight on the fronts
xtweakerx
Get SOME!
Palm Beach, FL
i dont have the stick on's, i have the kind that clip onto the edge of the rim, u got weights no your back ET Streets matt?
Matt D
S197 Pilot
Toronto,Canada
only thing with my fronts is they are both angled out a bit I cant figure this out -_- I have had like 3 alignments
gijosh28
Bad Penny
Savannah, GA
have em... I have the Qa1's but the plates go under the strut tower so there isn't much play.. Maybe I need to used camber bolts aswell down low to make them straight.. I hate it
Funny mine do the same thing. I have eibach pros, tokico d-specs, steeda bumpsteer kit, and mm cc plates. Even after the alignment they seemed like they were angled out to me.
GI Joe
I had to use both...sure did...
N
navbtcret
Guest
I just got off the phone with Race Star Industries. They have a direct bolt on 15" street/strip rim available for our s197 Mustangs. Some of the sizes are available now and the 15x10's will be available the second or third week in October. These are one peice cast aluminum rims, the fronts weigh 10lbs. and the rears weigh 13lbs. This is for real and about time someone came through for us Mustang owners. They are very reasonable priced also. You do not need longer studs for the rears neither, these fit the stock studs.
Here is a link to their website.
http://www.racestarindustries.com/
Feel free to call them, they will put you on their list and call you when the rim size you want comes in, I am already on the list. They were very helpful with me and actually called me back right away too.
Chris06GT
Dragging LS A..
Alabama
Look like Greg Weld's....If they fit good, without any issue's...count me in for sure....damn nice wheel and nice price....
