gijosh28
Bad Penny
Man that car is starting to really come together with the rims and that hood. The rears definately need to be a bit taller.
thanks...im going to look into the bmr and prokit...A 28" in back and a 27" in front will look good with some BMR springs or Pro Kit
what no, im talking about the actual "Weight" you put on the rim to balance the tire/rim when mounting.
i dont have the stick on's, i have the kind that clip onto the edge of the rim, u got weights no your back ET Streets matt?
only thing with my fronts is they are both angled out a bit I cant figure this out -_- I have had like 3 alignments
camber plates?
have em... I have the Qa1's but the plates go under the strut tower so there isn't much play.. Maybe I need to used camber bolts aswell down low to make them straight.. I hate it
