a HUGE Thanks to a great friend in Dave (Stkjock) I was able to pick up a set of slightly used (15 total passes) Bogarts for track use for a whopping $550 with tires and 2 sets of Lugnuts. The tires barely have any use on em which is a plus for sure.
They have MT ET Drag 28x10.5x15 in the rear and MT ET Front 26x4.5x15. That being said. I always thought you should have the same diameter tire, frotn and rear. Is this not the case? Should I look into changing the front tires to be a 28" diameter tire?
pics:
pics:
