How Much Does It Weigh?
Matt D
S197 Pilot
Toronto,Canada
Anyone weigh a single magnapack muffler? Just want to know what I will be loosing for weight by switching to these
Matt D
S197 Pilot
Toronto,Canada
Mac mufflers 12 lbs each
So I would knock of 6-8 lbs by going to magnapacks
Don I hope your still updated the list! lol
ArizonaGT
Road Course Member
Phoenix, AZ
I wonder how much Borlas weight...
I'm running stingers as well, they certainly FEEL a lot lighter than the stock mufflers and GTAs. But I run those for the sound, not for the weight savings--that would just be a bonus.
Other weight savings exhaust ideas--straight pipes w/ no cats :)
Matt D
S197 Pilot
Toronto,Canada
I already ditched the cats when I did the kooks long tube and X-pipe set up :p
Kaldar142
Silver Spring, MD
Did you get a sparco steering wheel yet? you would love the feel! lol
What weight reduction methods have you done so far?
I remember you said you had some sparco seats
Na, not yet...been dying to get one lol
Yeah, i have Sparco EVO 2s (yeah im a chubbb)
I've hollowed out every bolt that does not hold in a vital component, drilled holes throughout the car, removed windowshield wipers, run low brake & powersteering fluid.......LOL NOT
Pretty much everything that you have to be honest. the only differences are in the areas that seperate our type of racing such as brakes, suspension and wheels/tires
I have also removed random brackets and whatnot from the car, can't even remember the actual parts that i removed since it was a LONGGGGGGGGG time ago
Matt D
S197 Pilot
Toronto,Canada
Yea true, we have two totally differn't styles but some methods can work for both of us
Matt D
S197 Pilot
Toronto,Canada
I ate a bowl of soup at lunch instead of a cheeseburger :roflmao:
Good idea, just piss it out lmao
it's funny I almost bought another 05 gt for cheap locally and though of making it a road course car o_O but then I though better not lol
dragpac
easton,pa
so whats the weight of your car w/driver
ArizonaGT
Road Course Member
Phoenix, AZ
Yeah, you'd better not build a road course car...then you'd be hooked and spend even more money on these fucking cars!
Kaldar142
Silver Spring, MD
Not sure, still need to get it weighted but I added all the weights I took off and subtracted it from 3450. Should be around 3300 with me in it.
Could be way off though, the watts link and procharger added a good 100lbs... So it's hard to say and I don't like to "guess" weights.
I plan on getting front & rear aluminum bumper beams which should save about 30lbs. I will also remove the rear fuel evap canister which is around 25-35lbs(can't remember exact weight).
Other than that there's not much left to do for me. If I can find lightweight rear rotors then I would get those, but have not had much luck.
I've also been thinking of removing the windshield washer fluid resevioir as I NEVER use it...
