How Much Does It Weigh?
marksti
Anybody remove the A-Frame heavy metal supports??
They sit under/in front of the back seat, seat cushion.
I installed a roll bar/cage a while back and had to remove the factory ones..they were porky.
DusterRT
Defected to Deutsche
Seattle, the Sunshine City
Few more data points....
Corsa Touring axle-backs (pair) - 38#...heavy SOB's
Magnaflow catted X - 20#
GT Spoiler - 3.5#
GT grille w/ fogs - 4.5#
FR500S grille - 5# - yes, heavier than the GT grille!
bullittrevor
In the past month i spent only $750 bucks and Ive cut 198lbs out of my race weight
Bogarts with tires $500 - Saves me 128lbs over my street rim setup that ive been using at the track
Summit Seats - $250 - Saves me about 50lbs over the stockers
20lbs of personal weight haha
My current race weight should be 3829. much better
how hard was it to take out the stock seat and install this one. I'm thinking of picking up two Corbeau CR1 seats. It would save me roughly 60lbs pounds over stock.
foolio2k4
Buena Park, CA
Nice link,
I'll get that!! Do 2010s have the same roof as us?
Yup everything is different except for the roof. I emailed them to confirm. I also asked if they will create parts for 05-09 cars and they possibly will.
If their 2010 hood weights only 4 lbs then i can only image an 05 version will be the same.
94tbird
4R70W FTMFW
i am making the brackets myself to adapt the seats. prolly spent 60 bucks in materials. saves 140 bucks over the corbeau brackets
JeremyH
3V Fuel Guru
Virginia Beach
Rear stock rotor 13lbs, baer 14'' rotor 13 lbs!, caliper adaptors less than a 1lb.
Front stock rotor 19lbs, baer 14" rotor 19lbs!, caliper adaptors less than a 1lb
Forgot to weight the baer 6p caliper and stock caliper. BUt he 6p feels alot lighter.
94tbird
4R70W FTMFW
unacceptable. take it off and weigh it
JeremyH
3V Fuel Guru
Virginia Beach
Yeah is 6 piston 2 piece internal crossover all aluminum, well i t turns out i just may have to remove it because it looks like i got the wrong mounting adaptor that goes btween the 6p caliper and the spindle.
JeremyH
3V Fuel Guru
Virginia Beach
Will be weighing the stock front caliper and the 6p baer caliper sunday at gregs as well as the stock fan and shroud.
JeremyH
3V Fuel Guru
Virginia Beach
Good news i lost weight with these brakes!
Stock front caliper with halfworn pads and rubber brake line - 12lbs
Baer 6P caliper with stainless steel brake line, pads and caliper adaptor- 8lbs
So i lost 6-7lbs with Baer 14" rotors all the way around and 6P calipers up front!
