Jared's GT500 was actually running C16. The car was making a lot of power at 22 lbs of boost and than was being shifted at 6,800 RPMs. The tune was fine and it wasn't running pump gas. Jared said it before the car just had the shit beat out of it and that's why it blew up.
Ok, then I stand corrected but you just solidified my point for me. Running +4lbs (over OP's 18#) with C16 with a good tune and it went down. I was not trying to knock Jared at all, I was just looking for a quick failure example.
Well...Going rate to R and R a motor is 1500.00, then add motor assembly, blower assembly,.....yada yada...yada
I wouldn't know, I've never paid someone to build an engine. I always figured, if I can repair a turbine or a compressor I can build an engine. It has held true so far.
