05yellowgt
Are you running a 6 or 8 rib pulley setup? You are almost certainly experiencing belt slip with the smaller pulley which is why you are seeing the boost drop to 7-8psi up top. Go look under your hood and look for black dust on the blower pulleys and around the general area where the blower pulley is.The more restrictions (stock heads,cams, exhaust manifolds, etc) you have the higher the boost pressure is going to be. The TVS blower that the E-Force setup uses is more than enough to push your motor to the 550-600rwhp range IMO. Stock heads and cams, though they don't give as much power as a good ported set with blower cams, won't reduce his boost pressure.
