clunking after LCA install
captainN8
LaPorte, TX
Wanted to get some thoughts on what might be clunking after installing my LCAs. They are the tubular type with poly bushings. Seems to me like it could be the driveshaft, any thoughts?
JeremyH
3V Fuel Guru
Virginia Beach
If the bolts aren't torqued all the way down they will vibe loose and make a clunking sound.
white05gt
Illinois
Did you have the suspension loaded when you tightened the bolts? If not, go loosen the bolts up and retighten with the wheels on the ground or on jackstands and let us know if that helps.
captainN8
LaPorte, TX
i greased them like a mofo! i have heard of it making noises so that's why i did. i was going to see if you guys think that may be normal, then i'm not going to worry too much about it. i will add grease fittings later to them also. it may just be that they are new, i haven't driven on them much yet, but you can feel that the rear is much more stiff.
captainN8
LaPorte, TX
yes, had jackstands under the rear axle tubes.
bigwilly43729
I do stupid shit, a lot
Oklahoma: Not terrible
I ended up driving the car up on ramps, jacking the pumpkin a tad, then placing the jackstands under the tubes. It kept the suspension at ride height the entire time. When I just jacked one side of the car up at a time and did it, it didn't load it the same. I don't really know why, but when I did it the other way (with the ramps), the clunking went away.
Take a marker or a piece of tape and put it where the plastic top of the shock ends when the car is on the ground. That's where it should be when you torque it down.
JeremyH
3V Fuel Guru
Virginia Beach
+1. I use ramps as well when removing/greasing lca's
Bingo
Because street car
Phila, PA
This is what caused my clunking originally...
confuzed
what brand? i just installed BMR lowers and relocation brkts on my 2010. i got the poly on one end and sperical on the other. torqued em down with suspension loaded and mines nice and quiet. i was actually expecting a lil 'clunkiness', but im very happy how mine turned out. just gotta do the upper with mount here soon.
captainN8
LaPorte, TX
Yes, they are on the correct sides. I checked and double checked that, cuz the instructions they came with were not very good. They are J&M.
captainN8
LaPorte, TX
I am just glad to see that this is probably "normal", that was really my only concern. I will check the torque on everything as well. Thanks for the input guys. This is my first Ford, Mustang, and 3 link rear, which i am not familiar with. All i ever owned was leaf spring Chevy trucks........
Ken04
gm troll basher
Santa Rosa Ca.
FYI I have the J&M's also, haven't installed them yet, hopefully this weekend. When mine arrived they had no zerk fittings. I asked about that and the company replied that they don't install zerk fittings anymore to stop owners from using the wrong grease and destroying the bushings, FYI. I see you said you were going to install zerk fittings. I would suggest finding the appropriate grease if you do so.
johnny06gt
OKC
just drive it---i have adj uca with a spherical endlinks---was loud as hell when i put it in--drove it about a week to break it in--and it went away for the most part
NastyStang113
Made in U.S.A.
Central Florida
It's not normal. Mine makes no noise.
captainN8
LaPorte, TX
Since for some reason i can't use the quote button........ I used the grease that came with mine from J&M it was like friggin glue, nasty stuff.
Yea i figure they will break in and probably not make any noise, thanks for all of the replies, but like i said i will check my work again anyways.
