I'm looking at picking up the GordsFord Heat Exchanger sometime soon and have a few questions. I know there is some controversy as to which side to use for the inlet and which to use for the outlet. My questions are as follows:
1) Can I use the stock Saleen coolant hoses setup with this HE? Is it just a simple bolton, or does it require some custom tubing or custom mounting brackets?
2) On the GordsFord HE, are both inlet and outlet nubs on one side or opposite sides?
3) Which side should be used for inlet/outlet?
4) I'm running 10# of boost, do I need the fans?
Thanks!
Thanks!
