TSB 07-23-1 help
JeremyH
3V Fuel Guru
Virginia Beach
POst up the problem and what the tsb directs you to do if you want technical answers.
Riptide
Will work for Mustang.
Montucky
If I had things to do over I'd get a combo poly/rod end LCA. I like the ones that have a port to grease them with so you don't have to remove the thing in order to grease the bushings.
Mustangmoomey
Ypsilanti
What about these.BMR tubular A-arms are a lightweight alternative to your factory stamped steel arms. We offer them in two styles, standard and adjustable. Both models feature CNC machined rear pivot points, heavy duty 1.25" DOM tubing, and new ball joints sourced from Fords OE supplier. Unlike our competitors, these A-arms are also compatible with your OE K-member.
JeremyH
3V Fuel Guru
Virginia Beach
I have bmr a-arms, good product not a necessary part that needs upgrading its soley to drop weight. Focus on the rearend first.
Mustangmoomey
Ypsilanti
But the noise in the front end is driving me crazy.When I drive on rough roads it sounds like it's going to fall apart.And the tsd says to replace lower arm assb will this stop the clatering in the front.Thanks for all the info.
KoolerSL2
Serve and Protect
Jackson, TN
my 09 had this issue come up.
they will end up replacing the front lower a arms with the new design.
JeremyH
3V Fuel Guru
Virginia Beach
Yeah if your sure its the a-arms causing the noise, i say why not up grade to the bmr a-arms. They are $$ new, i got mine lightly used for a great deal.
