Agreed, but two or three cars with a 125 shot of nitrous, owned by shops that are using race gas under mostly controlled conditions does not make a good example. We ran a stock 3v to 600rwhp over the course of 2 race seasons. It lived because we used $11/gallon fuel.
The fact of the matter is the rods are the same basic material construction of the 3v, the piston is the same basic material as the 3v, so in turn with the exception of a rod that may be slightly stronger by design (slightly meatier)will have a slightly higher failure point assuming the same conditions. However the conditions are not the same as the 5.0 does truly like to be near RPM. Making power boosted, or sprayed at that rpm will eventually fatigue the rod. Especially when attempted by the common man on regular pump fuel.
I say that under conditions that most board members expose their car to the engine will fail at power levels near 450....But it will not be uncommon to to see it a bit earlier.
Folks need to keep in mind that the two fire breathing, nitrous snorting cars that are out running around right now are run under controlled conditions, the fuel is from a known source, All of the temps are kept at bay, and the runs as well as the track they are running are selectively chosen. Until there is more data these two in particular are as much as anomalies as they are the rule.
