1fastpony
- Joined
- Jul 23, 2009
- Posts
- 828
- Reaction score
- 3
Installed the Spec 2 a couple of months ago. Everything seemed good to go so I wanted to see if it could not only handle normal N/A track visits, or the occasional 75rhwp n20 hit. This clucth is rated at 599 tq and, spent some phone time with reputable speed shops. Consensus was it should work fine. Also installed the braided line to HTOB and drained the old tranny fluid and added Mercon IV. Car shifts smoothly during normal driving and speed shifting as well. CAR Tranny/Clutch engages and dis-engages well under WOT, no Notchy feeling, peedle is very light during WOT speed shifting. Been to the track twice and no miss shifts, all confidence is returned. Well it's been hot down here and there was a Event going on at Gulfport last night so me and my youngest deiced to go see and make a n20 pass. We didn't find out till we got there that you could take a passenger along for the ride. So my 12 yr old got to experience his first track run and it was a solid 12 second run N/A with crappy traction...1.8 60'.
He was all smiles.
Next up was the n20 run. Car cooled down good 45 minutes under the EH2O pump. Bottle on. good psi..1050 psi. Burn out good, stage and ready to go. Car next to me is a mid 90's Munstang Gt with some bolt-ons and cam...low 14 second car. Light turns last amber and we leave about 4500-5000 rpm. Window switch is set at 3200rpm to 6100rpm and spraying out of the hole. Car initial hooks and you feel that n20 TQ hit and it gets soft. shift to second and and same but you could and see/hear the car/tach over rev back in forth. By the time I went to third it was worse so half way through the gear I shut it down and let the other car go by. Son ask why you slow down and I told him the clutch gave up.
Go to the slip shack and left and could tell the clutch seemd soft starting off and into second. Back at the pits opened the hood and there was that smell. Not bad but there. James (JRC07GT) came over and mentioned it looked like I left like Garmma leaving the grocery store...HA HA.
Well, that was it for the night. Aired upt the M'T Dr's and let the clutch cool a bit and drove home 45 hwy miles. After cool down it seemd back to normal when letting the clucth out from a stop light and no slippage during some acceleration. Did the 4th gear low rpm and 5th gear test and appears no problem there.
Not sure what went wrong. It was a hot night so I don't know if that was a factor in the clutch cool down between runs. Thought I would again post this info for others to consider.
He was all smiles.
just dont get along, i have heard too many horror stories about specs on many different applications. Hopefully the slave is intact and you can get some usage out of it.
