+1. I used the Earl's on the OE calipers, and have the Russel design on my Brembos, and I can't see how either would fail in the manner you describe. The only real difference between them is how the spring is applied...
The Earls use a plunger, with a cone seat, tensioned by an external spring. When you tighten the bleeder screw down, the screws force the plunger firmly against the caliper casting, sealing the unit up. With the bleeder loosened, the spring is the only thing holding the plunger/seat against the caliper, which allows the fluid out for bleeding, but the spring seals the seat up on the release stroke of the pedal, preventing air from being sucked back into the caliper.
The Russel design is actually simpler, since the seat is part of the bleeder screw already. Above the tapered seat, there is a hole in the bleeder, that is sealed off by a check-ball, which is held in place by a spring, all inside the screw. If the screw is tight, there's no way for the fluid to reach the hole, so no leak. With the screw loose, pressurized fluid will move the check-valve, and escape (pedal being depressed), but on the return stroke of the pedal, the spring forces the check-ball to close the path, preventing air from getting sucked in.
Both designs are simple, easy to use, and essentially foolproof, with no complicated sealing mechanism to fail and allow the fluid to gush out as you describe. The only way for that to happen is to leave the bleeder loose. With a stock bleeder, if it's loose, it'll leak as well.
With stock calipers I had to bleed once or twice a day, depending on the amount of track time I was running, as well as the amount of abuse I put the brakes through. With the Brembos, though, I'm not having to bleed all that often. Before each track day, sure, of course, but very rarely around the lunchtime break, like I used to.
Rollo: I use the speed bleeders and a simple catch-can for the fluid. Crack the bleeder open, attach the hose, give the pedal 4-5 full strokes, close the bleeder, top off the fluid, then repeat at each corner. Done. It takes longer to type it than it does to bleed one caliper.
