2011 GT Front Suspension MODS
luillo
Fort Walton Beach, Florida
So far i used my UPR Front Swaybar Delete/Radiator Support with no problem and i looked at the K-member and A-arms and they look the same as previous S197. I am planing to use my K-member setup but i need to tech help here from those how know and have been under the new 2011 GT...
On the Letha Performance web site the are selling a BMR front K-member and is the same Part number as the old one so i assume is the same parts.
http://www.lethalperformance.com/20...on-adjustable-a-arm-front-end-package-p-32520
I dont see any problem with the A-Arms but i am not too sure about the K-member because of the new assisted power steering. I will make a call to the during the week to make sure is ok to use the K-member but if some body can give some advice it will be nice...
351inside
Houston Tx
its sunday man, post count is not as high as weekdays from what i have noticed you know
2011CS
2011 California Special
I called BMR on this and other questions and all they said was watch our website for new releases soon.
Big help there :(
19COBRA93
Ford Racing
Clinton, Ut
According to the Ford part numbers, the 2011 K-member is different from the 05-10. I have no idea what's different, but they are different numbers.
kyoshosp2
Baton Rouge, LA
Lethal Was at mustang week with us. they had a 10hr trip home sunday nite too. They will be back today.. latest tomorrow.
2005mach1
michigan
So did you already install the sway bar delete? was it and old(2005-2009) swaybar delete?
luillo
yes sir. The only difference is that the 2011 have an extra 2 supports bars that attach to the radiator support coming from the K-member. You can take them out or do what i did.
I install them back to the K-member and zip tie them to the UPR Rad/support with two pieces of foam under that way i dont have any noise or scratches in the UPR bar. You only need them to put the plastic cover under the car. I did it to make the car look as stock as possible.
i will post picture later
luillo
i think i will go under the car to measure the distance, high and location of the power steering bolts from the stock K-member and the the BMR and see if is possible. then i will call the vendors and verify. By just looking at it, the K-member it self is the same but the power steering cover so much that it might be different.
luillo
well, i just got off the phone with a representative of BMR and i asked him the K-member question and he told me that it will not fit so i will need to call Lethal and ask about what are they selling there.
DAMN IT.LOL
2005mach1
michigan
DAMN IT.LOL
That sucks
I wonder if it will fit if you put a manual rack in
