Your guys temps are normal with the systems you currently have and your setups. ive tried many things to get the temps down. right now im around 140 at the end of the strip with no heat exchanger and a Killer Chiller that isnt at total efficiency yet. I need a larger or secondary pump as well as a slightly larger tank, about 2-3 gallons
give me all the info you got haha
You guys should look into water injection, or windshield washer fluid. Cool that charge down a lot. I just added the trunk mount kit from AIS and all I can say is when the pump goes on, the IATs drop. I havent had it to the track since the install (need to find a babysitter ASAP).
