Uca question.
fordracer666
So I've ran the times in my sig. Here's what my suspension consists of.I've got stock shocks and struts. With cj springs and non adjustable lower control arms. And relo brackets. And I run consistent 1.6 60fts! So here's my question
I have a brand new adjustable uca sitting in the garage. What would I benefit from installing it?
I think the 1.6's are pretty respectable with what I have.
AlbertD
Tucson, AZ
I was in the same boat as you were... cutting 1.6s with similiar mods (stock springs/shocks, just LCA's w/brackets). When I put in the UCA w/mount I noticed my 60ft times became more consistent, not to mention that I also got rid of this annoying clunk... which I would assume was coming from that piece of crap stock UCA mount. I would definately recommend upgrading the UCA w/mount. Your launches should be more consistnet and you won't have to worry about bending the stock mount.
fordracer666
Mount
I understand the point in having a stronger mount.
I consistently pull 1.6 all day!
Maybe it could help me run low 1.6's?
I have some skinnies I'm gonna run next
Time I go also!
captainN8
LaPorte, TX
Damn, maybe that's my problem since I put my LCAs in!
REDS197
Denver
If you are cutting 1.6 sixty foots i dont think there is a great deal of improvement to be had. It will help some maybe 2 tenths if you lower your sixty. Be prepared for the new vibration in your car and its a pain in the ass to install yourself without a lift its a 2-3 hour job.
dysan
Dis-Member
Williamstown, N.J.
I don't get any added vibration since I installed my J&M Extreme UCA, and it's not a poly end either. What I will say is that I do hear the gears in the rear more than before.
fordracer666
Uca
Well I guess im in no rush to install it then ! If I'm not gonna get any benefit and more noise and or vibration.
