Twinscrewgt
Bad Smurf
Well I got my magnaflow competition 3" cat back installed with my lethal performance offroad xpipe..
If you are doing this in your garage its a bit tricky. I had to put the car on jackstands, lower the diff, unbolt the bottom of the shock and lower it as far as I could. The driver side came out with some help, the passenger side, I had to pull off the panhard bar brace, and pull the spring out.
Once the old was out the new went right in. However, the lethal xpipe seems to be about 2" to long. I had to trim a bit off the catback to get everything to line up.
After all that, it simply sounds amazing. It has the perfect tone while cruising and sounds orgasmic at WOT.
The quality of this system is top notch.
http://www.youtube.com/watch?v=ckhRoHrg7mY
