Jim Vaccaro
- Joined
- Aug 23, 2010
- Posts
- 175
- Reaction score
- 0
How do you engage Sport Mode ??,,,I thought you just dis engaged Traction Control
while depressing the brake pedal, double tap the traction control button. It will display sport mode in the instiment cluster info center.
Thank's...Sport Mode dis engages all Advanced trac ??
I ask because just dis engaging traction control while loosing traction on 1 to 2 shift the traction control still made the car BOG DOWN
Owners manual has a full explanation. There are 3 modes:
1. Traction control off = stability control on, traction control off
2. AdvanceTrac Sport mode = stability and traction control on but allow for more spirited driving
3. AdvanceTrac off = stability and traction control off
When you are at the track, you want to have AdvanceTrac off. To engage, step on the brake and hold the traction control button down for roughly 10 second. A message will display AdvanceTrac off.
Hope that helps.![]()
I always drive in sport mode.
Steering is much firmer and you can spin the tires without the back end taking off on you.
Confirm brakes on and double tap the button, you can even do it while in motion.
Does anybody know if there is a way to make sport mode stay on after you shut the car off and restart? I have to turn it on every time I start the car.
Can't be done. Sorry Dude.
I've seen it done, you just install a latching relay that "holds" the Advancetrac button down and it will disengage it when the car is started.
